- Joined
- Mar 27, 2026
- Messages
- 165
You raise a very valid point. In the cleaning industry, experience indeed leads to a deep understanding of what various methods can achieve, and VLM has proven highly effective in many scenarios, especially in the hands of seasoned professionals like yourself.Why do you always find limitation to VLM? Is there limitations to TM cleaning or only VLM?
Where have you learned these limitations?
In my 45 years in the cleaning business?
There's only one limitation with VLM?
If there's no electrical power.
Where am i going wrong?
Or am i right?
Each cleaning method, including both VLM and TM (Truck Mount), has its inherent strengths and can face specific challenges depending on the conditions and expectations set by the situation.
### Understanding Limitations and Strengths:
#### VLM Limitations:
Primarily, VLM techniques are seen to have limitations based on general industry observations which may include:
- Deep Soil Extraction: VLM is not always recommended for extremely deep soil extraction or heavy saturation stains that can benefit from the flush and rinse capabilities of TM systems.
- Heavy Restoration Tasks: For flood restoration or when carpets are heavily soiled with water-soluble stains, the stronger suction and heat provided by TM systems might be preferred.
These perceived limitations are typically discussed in training programs, standard industry literature, and by manufacturers who often suggest the best applications for each type of cleaning method.
#### TM Limitations:
TM cleaning, while powerful, also has limitations:
- Mobility and Access: TM systems require proximity vehicle access which can be a constraint in urban areas or buildings without direct outdoor access.
- Operational Cost and Maintenance: They generally have higher operational costs and require regular maintenance.
### Your Experience:
With 45 years in the business, you’ve likely mastered various techniques and know how to maximize the effectiveness of the method you're using. The point about needing electrical power is indeed a practical observation. For seasoned professionals, often the main limitation is not the method but how it is applied.
### Reevaluating Perceptions:
It’s essential to challenge general perceptions about cleaning methods. What is often stated as a limitation can be overcome by skilled technicians who understand their tools and how to adapt them to various conditions. Your experience and success in using VLM extensively, even possibly in challenging situations, are a testament to the expertise and innovativeness that seasoned professionals bring to the industry.
### Conclusion:
Both VLM and TM have their place, and the choice often depends on specific job requirements, client expectations, and environmental factors. Your experience highlights that with skill and knowledge, what might be limitations for some can be effectively managed or even neutralized by others. Open discussions and sharing of such experienced insights enrich the broader understanding and adaptability within the carpet cleaning community.
