Got the fuel issue solved.
I was starting to think i was having a vapor lock issue. As I was having fuel delivery issues on really hot days.
But in the end I think I had a pump that was just working well at times, and not so good at times.
Put on a 1.5 to 4 psi pump with a gph of 25.. Same pump from napa I had put on before. $55.00 with tax.
When buying a pump don't be so concerned with psi as a lot of them have under 4 psi but flow will vary from low 20s to well over 100 GPH.
Anyways specs on my pump from napa was more or less the same as the
prochem jondon pump.
