14" Gekko Squeegee Tool two in one?
J Scott W
Jeffrey Scott Warrington
Can I buy the 14" Gekko Squeegee Tool and the 14" Gekko Brush Replacement (brush assembly only) and changed as need it so I can have two tools is one?
http://interlinksupply.com/index.php?item_num=AR51E
http://interlinksupply.com/index.php?item_num=AR51B
Thanks in advance
They are not made to interchange easily. You would have considerable work each time youw anted to change and the fit would not be perfect.
If you purchase a squeege head right now, I suggest you check it out in person. We had a batch with some poor quality rubber out. We have replaced allwe tracked down and found, but there are several unaccounted for. Check the rubber or wait about 6 weeks until we are sure they are all removed from any distributor's stock.
The brush head model is fine.
Reactions: Art Kelley
