Auction 175 RPM Floor Stripping Buffer 20 inch
MB Auctions
Description:
This 20 inch floor stripping buffer is great for any extended use with our Green Seal floor stripper, or any other type of caustic material. The body and apron will not corrode, decay, or rust over time, like many of our steel rotary buffers. This durable floor stripper utilizes a 1.5 HP motor, and a triple planetary steel gear transmission for continuous power when stripping those really tough finishes. Comes backed with a 3 year warranty on motor, transmission, parts, and labor. Take a look at our floor stripping instructions for tips on how to properly strip a commercially tiled floor.
The CleanFreak floor stripping buffer's poly apron will not only stand up over time, but it also makes this machine lighter than most models of comparable size. At just 86 pounds, this 20 inch machine is easy transport from job to job. The single capacitor helps in those extremely tough start up situations, like those involved with stripping floors and scrubbing carpets.
Click here to view additional specs on CleanFreak.com
$695.00 Retail Value. Free Shipping to Lower 48 included.
** You must create a CleaningClassifieds.com account in order to bid on items. Your Mikey's Board credentials will not work. Click the following link to create your account: http://cleaningclassifieds.com/register.php **
