19 INCH DIRTNAPPER
Will this fit on a 17 inch Tennet 2 speed buffer?
Dallas, Texas USA
Jimmy;
It has a riser that moves the brush down about 2".
That 2" the clutch plate may be enough to clear the skirt.
You can measure from the clutch plate drive to the skirt for the required clearance.
The brush can be spaced further down if required.
Mikey Board Supporting Member
