I assume they're toast right?
Or is motor replacement an option?
shiteatinggrinJim Martin said:the thing that is going to take the biggest hit is the armature and the field......rust is going to build up between the 2....set them out and let the electrical dry out ....then use some contact cleaner ( it is non conductive ) and see if you can spray some in between them both and fire it up and let it run for a bit.....once you get it going...spray the hell out of them and let them run.......they should be good as Bawb new......
