2004 UD tip
I was noticing that my air flow on my A/C-Heater was getting worse. Right under the fuse block center dash is a cover with 4 screws and then you have to remove 2 screws on the fuse block and let it hang. Thats when we found 2 screw in the front of the heater assembly (not the fan housing). Those 2 screws are the screen filter that was about 90% clogged.
Wow we are back to full cooling and heat !!
can you take some pics of what you are talking about. thanks.
yep....it is called a cabin filter...one should pull it out at least twice a year and clean it......
BradFenstermaker
When my airflow stopped a new fan motor from Oreilly's fixed it.
Anybody needs the part number I saved the box. About a quarter of the price to UD.
