30 volume ?
Ammonia? If that is what you are talking about than yes,if your gargleing with it you better cut with a lot of water :D
Kevin McCreary
Make sure you don't get it in your eyes!!!!! If you do dilute it with water to bring down the % use cold water.
if you're going to dilute it with water, just buy pints or quarts of 10, 20, 30, and 40 vol and use as needed instead.
no mixing then.
Just screw on a trigger sprayer and spray away
Kevin McCreary
I always buy a 15 gallon drum of it in 40 volume then have to dilute it from there.
My Dad has been using that peroxide ammonia trick since the 60's and that's the cheapest
way to get it bulk. Before there was a Haitian cotton cleaner we used to intentionally brown them out
then come back and reverse it with h2o2.
floorguy
Doug
uhhh you understood that shit????
blah blah garggle was about all i got out of it....
Art Kelley
The question was oblique enough to warrant unintelligible responses.
