- Joined
- Oct 6, 2006
- Messages
- 117,214
raised the swoops 5/16ths..
Hope it cures the streaking issues.
Jim;Jim Martin said:the hardest thing on a motor is.....start up...if you look at the ratings on them..you will see 2 different types of amps on the tags..start amps and run amps...start amps is where the amps will peak when you turn it on because of torque ...run amps is maximum amperage it is allowed to hold before you start having problems...
the 360i... has a servo motor..(or variable speed)..these things are really cool little motors...but they have a down fall..they are not really made to take torque....they are designed to start something out slow.....bring it up to speed and then slowly back it down...in time it will chew the brushes and damage the internal parts because of the pressure that is put on it...they work great for things that are designed to "free spin" and rely on a variable speed motor to bring it up to power...and control what it is running...on the 360i the more you use it the hotter it gets..on thicker pile carpets is where it gets the hottest...the lower you put the speed it the more strain it will have trying to keep the head turning....so it will not have a long life like the others.....it can not handle this type of application...at 250 RPM's.......how much more torque do you think the added pressure of a 4th vacuum slot will add to this motor....
Jim;Larry Cobb said:[quote="Jim Martin":3cdyfju5]the hardest thing on a motor is.....start up...if you look at the ratings on them..you will see 2 different types of amps on the tags..start amps and run amps...start amps is where the amps will peak when you turn it on because of torque ...run amps is maximum amperage it is allowed to hold before you start having problems...
Bob Foster said:Must get close or over FLA on start up. Do they pop 15a circuits? Hard start circuitry is adjustable?
Bob Foster said:Real hard on little motors. FLA every time it starts will make life short. How heavy a cord does it come with?
The adjustments are on the speed control board in the handle.Jim Martin said:what adjustments are you making.....there is not much to play with and torque is torque
have you amped it out...
The adjustments are on the speed control board in the handle.Larry Cobb said:[quote="Jim Martin":28n1zozg]
