I like it......I have used it on almost every job and all types of carpet.....
you really have to watch it on the higher pile carpets....it will streak on you if you go to fast and don't over lap...
I
think it is because of how low it sets and does not allow the jets to disperse the water evenly......
unlike the RX..the thing can hug the walls and edge really good...and as in the picture above...it goes under the beds and fits under toe kicks....normally I would have to grab the wand and edge those areas...but now I don't....
It fits into tight areas...under desk....small closets...and it really easy to maneuver around....
the recovery on this thing still amazes me everyday....the carpets are drier then when I was using the
Vortex.....
it does good on CGD....
took a bit to get use to and find the sweet spot with it........but it is a keeper.....
the only negative I can see with it........the thing slobbers like a St. Bernard....move it from room to room over a tile floor you better have a rag to wipe up all the water......wonder if a check valve somewhere might help this.........
