40 vol.
  • Thread starter prestige cleaner
  • Start date
P
prestige cleaner
new to using 40 vol peroxide for stain removal, what are recommended mixtures for removing stubborn stains, dingy traffic lanes. Can I use it straight or do you have to dilute? When can you use it and when should you not? Also can it be added to pre-spray to be used as a brightener, please need advise on this issue.
C
Chads
use the search function on here and you will find endless advice on it just type in peroxide.
Hi Josh;
I see you're a fellow Texan.
Here are dilution ratios for our peroxide product:
The Dynachem Liquid Brightener is 40 volume (12%) peroxide with a stabilizer and penetrating agent.
If your hands are clean, it will turn them quite white.
You can use it @ 6% (50% dilution) for spotting purposes.
I would keep animals and people off the areas for at least 45 minutes or so.
Larry
P.S. The Dynachem Powder Brightener is a stonger concentration, so you carry less on the truck.
Larry
