870 Maintenance
GeneMiller
gene miller
I always complained about the location of the drain on the pump. Maybe it says in the manual i didn't read but if you loosen the nut on the drain hose at the pump the hose will swivel without leaking. you can run it right out the front, which is where it should be.
GeneMiller
gene miller
I looked at a pump but I'm old school. i like to see the oil drain out the plug.
