A wet one
We had a couple of suites flooded over the weekend, these are a couple of the best pictures there. A couple of crews spent Saturday afternoon getting her extracted and dried.
They are back in operation, but most of the walls (insulated) are wet 1ft up with vinyl wall paper. We are going to have to work around the doctors as we drill and dry them out.
kmdineen
Redding, CT
Kevin Dineen
Nice job Richard, looks like a lot of affected walls.
Why didn't you remove the cove molding and drill or peel the vinyl wall paper up while you were drying the carpet? What type of insulation is in the walls?
Do to the time frame you had to dry before the business went back in operation was T.E.S. or E.T.E.S. used? Octi-dry or injectidry (direct it in)? I know you are very knowledgeable when it come to structural drying and have different types of equipment. Would you mind sharing what you used (snail or axial) air movers, TES, wall cavity drying, x-large LGR dehumidifier or a few small LGR dehumidifiers and why? Thanks
Sunday we had drilled the suite that had less affected, they were sure they wanted us to dry those walls. That suite it is almost complete, just a little equipment running there.
The suite hit the worst, the owner had his builder meet us yesterday. They initially considered removing the walls. I think the builder could get to it right away or did not want to remove the walls. He didn't even think they needed drying. :shock:
After shooting the place with a thermal and proving it to the builder with the meters what was wet, they finally decided that that drying was the route they wanted to take.
We usually drill through the vinyl cove base. If you remove it, you have more chance of damaging it, both in removal and during the drying process.
No TES or E-TES too many issues in heat up the rooms, medical equipment, too many walls.
Old school drying 1-inch paddle bit for holes, snail airmovers and turbo vents, Drizair 2000's. Not too concerned about mold in walls, newer building, but we did setup 4-air scrubbers throughout both suites as a precautionary.
12-hours drying, hard to see much progress. They are going to try to run some equipment during the day in rooms not being used.
These jobs are a pain to dry, just due to the short drying window. The Dr has a full schedule of work so you are limited on drying time. Just not much else you can do, but nurse it along until you get it dry.
With it being newer construction, were metal studs used? If so, was there any water trapped in the C channels? Also, if metal studs were used, any problems with rust or oxidation of the metal in turn affecting the walls or drying times? Thanks!
Hawaii
Yes those are a pain to dry... We've had a dental office to do and they'd make us pull the equipment every morning before 8am. Then replace it anywhere from 1pm - 3pm. And expect it to be dry in 1 day.... :roll:
Drilling through the covebase? That's a new one on me. Most times they make us reuse the base. I just use a knife to cut the paint right below the covebase and it comes off good because it's soft from the water. You know when you've hit a dry wall because the base doesn't budge... Just use the meter to confirm that it's a dry wall. From my experience. :lol:
We use to remove the cove base and then have a bitch of a time not damaging the vinyl wall paper from the airmovers.
Taping it, using tacks to hold it and having to make repairs to the paper, just because we left it lose while drying it in place- drill through it you don't have the issue.
The cove base is usually ruined in removal anyway. It's tough not damaging it when you pull it off. It gets white when creased or stressed.
Drill through that stuff! :wink:
Hawaii
Damn, good thing Hawaii doesn't have snakes, I totally over read vinyl wall paper :oops: ... I concur with what you mean about damaging the wall paper and/or base upon removal.
Hoody
Bowling Green, Ohio
Steven Hoodlebrink
Years of Experience
20
Looks like a PITA but fun drying job.
With vinyl cove I usually just score the top and slide a knife through as another person slowly pulls. Number the walls, and put the number on the back of the coving. Roll it up and set it aside, always easy to reattach.
Steve Smith
Nice job Richard.
What to you do with the holes in the base cove?
How do you bring it back to preloss condition.
Do you just replace the base cove after the wall is dry?
