Advanced Stain Removal Presentation Preview
This was some prep testing before my seminar this Friday @ Experience.
First Crazy Ray obtained some used nylon cut pile carpet in a light color.
We felt years old carpet would be closer to what you run into out in the field.
I wanted some very difficult stains to test on.
I chose DuraSeal stain/finish in a dark antique brown.
It was painted directly on the carpet and penetrated thru to the backing.
For the second stain, I selected a dark blue toilet bowl cleaner.
It was sprayed with a trigger sprayer until it also penetrated to the backing.
Both stained areas were about 3.5" wide x 10" in length.
The DuraSeal stain/finish dried to a hard dark residue on the carpet.
I needed a very strong solvent to attempt the removal.
I chose our Vandalism Remover aerosol for initial removal.
After spraying the bottom area completely, I worked it with a spotting brush for about a minute, and then extracted with a hand tool. Removal was good, but some streaks remained so I applied a second V. Remover application & rinsed with our H.D. Preconditioner.
The toilet bowl cleaner was next. Ray & I had tested this stain with our Fabric Brightener (12% peroxide) last week in Witchita Falls, but only removed about half of the stain.
This time I used a slightly stronger peroxide version and saturated the test area. I then adjusted the tripod of the Hi-Power UV light to provide about a 5" circle of intense UV irradiation.
This is a photo of the results with untreated at the top:
Several experienced cleaners thought that neither of these stains were capable of being removed.
Larry
Reactions: Shorty and JS41035
Dan;
Yes I did.
When DuPont was trying to remove mustard stains,
they used peroxide over 20% without harming the dyes on many different carpet samples.
This blue dye is very intense and required a concentration higher than our standard 12%.
My fingers did suffer some white spots :icon_rolleyes:
Photo of UV light & tripod:
Mark Saiger has some of the Vandalism Remover to test on some furniture stains in his operation.
Larry
D
dgardner
I'm guessing one has to go somewhere else besides Sally's for peroxide that strong.....
Dynachem has it, but it is best shipped with a freight order, since it is HAZMAT.
Besides, Sally's may have been hacked for ~25,000 credit card data,
according to Krebson Security.
They said some were purchased by banks monitoring cybercriminals.
Larry
Latest Auctions
