I just tried the new Devastator wand. First I will post my comments on the wand but I do have a question that I need advice on posted at the end. Keep in mind that I currently use an older style Prochem 3 jet wand.
The new Devastator wand:
- its lightweight! A big plus
- its longer than my current wand which is a big plus because Im a tall guy and my current wand is not back friendly.
- site tube! big plus I always wondered if it would change how I clean. It didnt change too much but it is a great feature so I can see how much liquid is being removed.
- it is a 1.5 inch tube. A big plus. even though I have large hands, its much easier to grip a 1.5 inch wand than a 2 inch wand.
- drying times. maybe a tad better than my current wand
- the swivel. I can see how it would be a big plus for some cleaners, but not so much for me. Since I hand tool around the edges and tight corners (where the glide does not let the wand face get to) anyway, the swivel isnt that important to me. Plus the fact that there are more moving parts and over time moving parts wear out. so if a non-swivel model was made, I would prefer that.
- the 2 inch to 1.5 inch hose. You have to go from 1.5 inch wand tube to 2 inch vac hose. The adapter hose is a great idea, but this is the biggest problem for me. I use a Prochem upholstery tool that I use to do the edging which is adaptable to a 2 inch cuff. If I got the wand I would need to figure out a way I could use the wand and switch to using the upholstery tool with little effort. At this point I could use a 2 inch to 1.5 inch cuff on the wand over an existing 2 inch cuff (which is what I did for my trial) but there is so much pressure on the cuff that it bends plus there is a vaccum loss between the cuffs. The other option is to use a 2 inch to 2 inch connector cuff to go from my vac hose to the adapter hose but then every time I edge, i would need to switch cuffs which would be very time consuming. If anyone has any suggestions on this, buying this wand would be a no brainer.
