Steamin Demon
Derek, I sell the steamin demon so you may think I'm biased, but I will tell you what we have found with our own carpet cleaning company. We have two steamin demons and have tried other portables. The reason we like the SD over other portables and even truck mounts is because they are light at 30lbs or so and very easy to use and versatile. I have seen nothing that will flush a carpet like the SD and the dry times are great. They can be used for flood jobs (as long as you don't set them knee deep in water) they will continuously pump down a drain or into the back yard. The standard units will pump 150 to 200 feet and the optional dual discharge will pump out 450 feet. Sense you can use just about any water and drain you very seldom need any where near that much hose. If you just pre-spray and extract they will clean as good as most portables, but if you pre- scrub with a rotary, OP,
CRB, etc they will give results that any truck mount will give, and better than most IMO. We had a Power Clean Genisis 59 truck mount and even using a rotovac we could not get the carpets any cleaner than we could by pre scrubing and using the steamin Demon. What does any truck mount or portable do? it simply squirts water into the carpet and sucks the water back out. Most of the actual cleaning is done by the chemicals, but other portables and truck mounts only apply about 1/2 to 2 gallons of water per minute, where the steamin demon applies 3 to 4 gallons per minute. The difference is that they are shooting the spray into the carpet at 200 to 500 psi and the SD is just flooding the carpet at almost no psi right in front of the pickup shoe so the water is flushed through the carpet fibers in larger quantities but is not driven deep into the carpet backing and pad.and is quickly recovered.
Thats one of the reasons the dry times are so good. We typically have 3 to 4 hour dry times in residential carpet and less on commercial. No one machine is the end all, but for most extraction jobs for the money I'll go with the SD.
BTW the MFS price on the classic is $3395.00 and the XL 15 inch is $2695.00 and the XL 20 inch is $2995.00. Our prices are less so you can email or call for your price. NOT that I'm trying to sell you one. LOL
Oh by the way I'm not knocking truck mounts, so don't get all over me.
Jim England
smart-cleaning-solutions.com
