Check your cooling system, no matter how well you think its doing..
Mine was over heating...changed thermostat....nope
ok took it out thats got make it run cooler.....NOPE
Thought water pump was bad, took out radiator...pump fine, rad needed repair work anyway a leak or 2..
Antifreeze was gross..GO CHECK OR FLUSH...
Tried it out today no issues, motor held 200ish no more of this 230 BS
ALSO WHY IS IT THAT THE MFG CANT PUT AN F'N TEMP GAUGE FOR THE MOTOR???? IT WOULD HAVE HELPED ALOT IN THE BEGINNING :x :x :x :x :x :x
GO CHECK AND/OR FLUSH YOUR SYSTEM!!!!!!!!!!!!!!!!!!!!!!
