tmiklethun
I just did a vacant home for one of my property managers. It is just under 1,000 sq ft. In addition to the normal cleaning the house had 17 red dye stains, 3 pieces of gum and a couple of weird blue stains. The majority of the stains came out.
Here is my question, normally I would charge about $10 - $15 per dye transfer area. It actually feels a little high for this job. I spent about a hour doing the red dye removal after the cleaning. My target per hour is between $100 - $125. At my normal rates I would be a minimum of $175.00 for the hour. Does specialty stain removal justify a higher per hour rate, or would you feel comfortable charging less do to the volume? Thanks
