Ricky Thurman
- Joined
- Oct 9, 2006
- Messages
- 275
Shouldn't a TM or any engine for that matter , once started, be able to run flawlessly without a battery as long as the alternator is working correctly.
My battery went bad on my Bluewave this weekend. I jumped it off and the battery would not take a charge, and the machine would cut out unless I left the jumper cables hooked up to the van.
It seems to me that if the alternator is not putting out enough juice to operate the equipment, then it cannot maintain a charge on the battery. Right?
I guess I should just pull the alternator off and have it tested.
