Amtex Truck Mount. How does it compare to Sapphire or Prochem?
JohnHawkP
Melbourne
John Paton
Brand new Amtex Truck mounts made in the USA from $30,995 inc GST. This model has a world first self washing waste tank at no extra cost. View it in action on our website.
Full customisation available, chose your own colour to match your business brand.
•Engine - Kohler Command 27HP Air Cooled Engine with Electric Start
•Blower - Roots 47 URAI Blower (528 CFM). Available with Belt or Direct Drive .
•Pressure Pump - Hypro 2500 PSI, Positive Displacement 4.8 GPM Pump
•Optional - Pump out
•Heat - Dual Super Charged Stainless Steel Heat Exchangers
•Self Cleaning Recovery Tank - 300 Litre (80 Gallon) Recovery Tank with
Exterior Filter
•Fresh Water Tank - 340 litre (90 Gallon)
•3 x 15 metre (50 ft) Vacuum 2" hose
•3 x 15 metre (50 ft) Solution hose with quick disconnects
•1 x 12" Amtex Stainless Truck mount Carpet Wand
•Full Manufacturers Warranty
•Finance available to approved purchasers
Servicing
The majority of servicing is based on actual hours you use your machine. The Kohler engines, Hypro pump and Roots blower will all required oil changes, These are very easy to perform by the owner. These hour-based oil changes should provide you with excellent worry-free performance.
Should you however need further assistance, we have nationwide service assistance for you to access. Unlike other sellers of truck mounts, we believe you should be able to access your servicing, parts and advise locally.
Kohler Engines – inspection and servicing by Kohler qualified specialists to minimise any downtime will provide years of usage
Hypro Pressure Pump - replacement parts from the Australian agent of Hypro Pumps.
Roots Vacuum Blower – just like the rest of the Amtex components, Roots blowers are manufactured to provide unsurpassed service. Should any parts every be required the Australian agents stocks a comprehensive range of service kits, parts and accessories.
Frames and Construction – Amtex only use the best materials available with hand welded precision engineering so that each truck mount is truly hand made to your exacting requirements.
Dare to Compare
At Cleaning & Restoration Depot we are so confident in the value of our products that we publish a detailed comparison of our Amtex truck mounts plus those manufactured by Hydramaster, Prochem and Sapphire Scientific and available in Australia.
You will see the true value for money our machines can offer with this side by side comparison. To receive this information, simply email us at service@crdepot.com and ask for a copy of Dare to Compare.
Meter Maid
The Undetective
Dayton,Ohio
Chris
I like the smaller guys. Might get a Judson next, only because I hate what's involved in regulating heat with HX's... all those parts make my TM tricky to work on.
Anyway... I talked to Ben a couple times... nice guy, but I just couldn't buy from him, got a HM instead.
Reactions: JohnHawkP
Meter Maid
The Undetective
Dayton,Ohio
Chris
I did get the chance to see a 14HP Prowler in action a few months ago in KC. It was shockingly powerful for a 33 blower. I hear it's because it doesn't have a waste tank to suck up valuable vacuum. It measure 20" of lift. Was impossible to move the guy's 12" wand without a glide. Heat seemed semi-decent.
