With the CFX set-up with the pod, is it possible to utilise the 250psi pressure pump, WITHOUT using the solution tank.??
IE: Can you hook up directly to the water supply, (fawcett), into the pressure pump to get 250psi at the wand.??
Thanks.
Thanks.
