Rotovac
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <wunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]-->[FONT="]Rotovac has now introduced a new 360i with a larger 15" carpet cleaning head. The 360i-15 cleans about 25% faster than the standard 360i and has a combination of 2 holed and 2 slotted Teflon vacuum shoes which leave the carpet drier and run smoother than ever. The Teflon vac shoes create much less drag than steel shoes on the carpet so the 15” head actually is easier on the motor than the 12” Swoop head. The holed vacuum shoes leave the carpet drier than slotted but don’t pick up carpet filler fiber and debris as well. The combination of the two (holed and slotted) gets you the best of both worlds. You can also customize it any way you want (all slotted or all holed). The 15” head and shroud kit will retro fit on to any 360i. This 15" head has been thoroughly tested by numerous cleaners in the field with fantastic feedback. The 360i is a proven design and the 15" head comes with a 30 day money back trial so you really can't go wrong with this unit. Check it out at www.rotovac.com. [/FONT]<!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->
