I bought a 2010 Cleanco Compact 47 last summer with @ 1600 hours on it. It's attached to a Ford E250.
I have run it since August almost exclusively, putting almost 500 hours on it. We had an EXTREMELY SLOW Winter but the thing has been rock solid, without a single hick up. I'm a little OCD and don't like how some of the covers rattle around while going down the road.
The performance is solid, not a glitch. I use a 14" wand at 6 flow and a RotoVac 360i. Both hold heat pretty well but I believe you would lose heat if you were using a tool with much higher flow.
The suction is great when using my Devastator in line filter. The factory waste tank houses a burly metal cage type waste filter. I leave mine in even though it stays clean with the Devastator.
Maintenance is almost a non issue. I have the oil changed between 2-3 K miles. My supplier is @ 3 hours away in KC. I took it down there a couple months ago to have him get me ready for Spring. He changed the pump and blower fluid, checked belt tension, set the "UPH" and "CARPET" settings to run at the proper RPM's. He said the belts looked fine so I took his word for it. I was prepared to pay him to change the belts.
I think enough of it that I will finally be putting a wrap on the van, which will cost me @ $3500. Chump change for some but not me while building my biz.
If $ weren't an issue , I'd look at Cleanco or
Butler. Cleanco, because I have help within a 3 hour drive.
Butler, because I don't think I'd need a supplier nearby.
Feel free to call me if you want more info. It's a great rig and it has my trust to take my biz to the next level. It's a good choice and a real work horse. I'm doing more and more large residential jobs where I flick the switch and run it for 4+ hours and don't worry about it.
The Clean Machine of Iowa
www.thegreatcleanmachine.com
