cleanman71
- Joined
- Feb 22, 2016
- Messages
- 9
- Name
- Jake
Currently using Nautilus 200psi and a wand. Would like to use a 360i and a VLM or Brush pro.
Please note that I meant this if you are only wanting a porty.....lol.Are you only wanting a good porty? Or are you looking for a TM?
If you are doing mostly CGD I would recommend a much more powerful potty and a Zipper.
Honeychild I have two bigass trucks.Anyone?!![]()
Lol...I just hope you aren't cleaning actual people with them! You missed my joke.....I suck!Honeychild I have two bigass trucks.
For single wand work my new combo does it all, for less.
I try not to do a lot of restaurants but I have a commercial IT account where they are always moving desks around leaving areas where the chair pads were, looking new an t rest not so much. I often use prochem citrus booster as a additive. Is this similar to your citrasolve?
A lot of of normal folk have been achieving excellent results with out the "Big" truck that's been touted for years!
Red.
And make sure its new as they wear quick.
Under a 1.5 horse 175, along with a liquid citra solve booster ( I swear by Chemspec BioSolve) you'll be blown away. Powder "solvent" just aint the same.
High flow, high heat, use a rinse agent and you'll be the king ding dong of resturants.
Zipper Wand is a big plus.
I think adding a brush pro to any system is the best thing you can do. You will get a better bang for your buck with that than trying to add a rv360i. You don't have enough pressure or flow to maximize the 360. Scrubbing the carpets with the brush pro will take care of most of the heavy soil and you should be able to rinse it out with your portable pretty easy. Anything doesn't come out, hit it again with your prespray and scrub it again and rinse. Make sure you are not using foaming chemistry or use a crystal defoamer. I'm looking at adding a 10inch brush pro as my next tool.
The problem is that sometimes the truckmount can't reach the job, hence the word "portable" In theory, the truck mount is always the better option, however, in the real world, the portable is sometimes the only machine that works for the situation.Sooner or later you haft a graduate to a truckmount......
That portable is 4000$......
You can find a 5000$ used truckmount add a kero or propane heater for 1500$
You will have at least 4-5 times the vacuum 2-3 times the water flow and 3-4 times the heat.....
Or buy a newer 10 k truckmount and add the kero heater......
You will be able to clean almost any carpet area no limits.......
Got rid of my portable within my first year as restaurants wouldn't talk to me without a truckmount....
