I use the two jet Mytee from Cobb it,s the $230.00 . I like it and have used many other over the years, It is light weight with the steel
glide, it has two 11003 jets.The main thing is that the base of the wand sits level on the carpets with the steel glide and the carpets is drier with each stroke. The wand does not slide as easy as the white plastic glide, but the more contact on the carpet is faster drying. The type of carpet you clean has a direct effect on the slide of the glide. I use this wand all the time for faster drying time but also have to work harder to clean the carpets on some carpets. The extra effort is worth it to me. Also this wand works for me at 5-10 but if your taller iit won,t work for you due to the legenth of the tube of the wand.
