I removed ALL..my fuel pumps on all of
Prochem.'s...EXCESSIVE HEAT..especially in the summer..
Re-mounted on the floors.."closer" to the fuel tank..these small fuel pumps LABOR
to DRAW fuel over 4 ft....But can PUSH the fuel 10ft...with NO problem... :wink:
On the Older 405 & 805...I ground to the frame...then extend the hot wire to the
ignition switch...The pumps last twice as long...away form the engine heat & HX...
Of course ....your switch controlling the APO...could be over-heating...shutting down the fuel pump.. :idea:
A good way to check if the fuel pump is OVERHEATING...is to position a BLOWER
directly on it...See if it takes it LONGER to shut-down...if at all...
One more question...After the unit..shuts-down..!!!..Is the fuel pump still running..?
if it IS...Your pump needs to be replaced..You have a FUEL problem..NOT electrical..!
It is overheating & loosing its PRIME...ETHANHOL..is a MAJOR factor in the "premature"
FAILURE.....
