APO.....
Arizona
what are the best ones out there and who make them....................?????
sweendogg
Bloomington, IL 61704
David Sweeney
You filling the puny little waste tank a little quicker than the old vortex tank? Question.. Why not consider replacing the waste tank with a larger capacity over an apo? Especielly with that nice 4500 series cab over? Just a thought.
Arizona
the puny little tank was upgraded to a 150 gallon the day everything was installed......I have my daughters school coming up again and even the Vortex tank could not hold this...so I am thinking a head of the game and with running a hose instead of working out of a fresh tank....and adding a APO....my life will be easier cleaning the school......don't have to refill tank or worry about dumping...
sweendogg
David Sweeney
good call.. I deal with a puny (IMO) waste tanke every day: 110 gallons just isn't enough sometimes. (since its plumbed to stop at about 80 or 90. )
I was kinda of hoping Mytee would have the truckmount version of their air hog out with the pump out built in like they have for their porties. Then it becomes a matter of a 150 gallon back up tank vs. a 12 V apo.
roro
Wellington
Ross Craig
When we maKe up our own units for in-lines we use Grundfos pumps - a bit dearer but well worth it - stainless steel, reliable, could handle semi-solids.
Our Accelerated truckmounts have continuous pump-outs and they are very effective and reliable. I don't know the brand but Duane may be able to tell you.
roro
Ryan
I have one just like roro's except mine is built out of 3/4" clear Plexiglas. It has a hydramaster pump in it I think. Never had a problem with it and I got it used.
rwcarpet
Youngstown, Ohio
Robert Hodge
My local ProChem dealer offers an APO that sits outside the tank. It's a diaphram pump, I believe. It can be added to any TM.
Mine is a belt drive, which would be a PITA to install on most units.
Remember the old Steamway Turbo matic, chain drive, clear plastic tubing pumpouts? They were unique for their time.
Arizona
steve frasier said:
rebuild the one you already have on the shelf collecting dust and you will be fine
avoid the hydramaster apo
gave it away to someone who needed one a while back..........who knew...
MicahR
Billings, MT
Micah Richardson
I would go with Bluelines apo. Had a lot of customers go with that one and never had a problem.
Dallas, Texas USA
We think the Mytee AirHog with our new higher-lift vac motor ...
will perform well with a TM ...
and boost the lift & CFM.
As Lee mentioned,
The ProChem diaphragm pump is probably the most proven design.
Larry
carpetcleaner
Gilbert, AZ
Rob Litwin
I have the HM one that I got with my Boxxer421. I use it on most jobs. I have well over 4000hrs on my TM. Not one problem with the APO.
steve frasier
portland oregon
steve frasier
you are lucky then but I put a little more sludge then most and the impeller just doesn't last, blueline apo I had with the Thermal Wave did much better
La Canada, Ca
La Canada Carpet Cleaning
We have the Bluline Hypro APO, You have to run a inline SS mesh filter. if you dont lint plugs up the check valves weekly. Kinda a pita to keep pulling off head. Now I clean the mesh filter regularly
Vince
carpetcleaner
Gilbert, AZ
Rob Litwin
I looked at my APO today. It is an external one that says it is made by Bison. It doesn't pump out to the bottom of the tank ( leaves about a foot), it most likely keeps the sludge out of the pump.
boazcan
Tampa Bay/Central Florida
Bryan C
Vince
vince, can a take a couple of photos of your filter setup and post, please?
Thanks.
