Applying solvent protector on furniture
What do you use to spray the protector on?
Best and most professional...............sprayer
One from Hydroforce/Interlink. Small 2-qt solvent safe sprayer. Its been improved works pretty well.
I was unsure since we used to use their stainless steel 2- gallon sprayers with the long hose and gun but these have held up well and we've sprayed at least a case of Fluorosil II in the last couple months.
I have a electric multisprayer but didn't know if the flojet pump could handle the solvent.
I can switch out the spray wand to a car wash type and put a smaller spray tip on.
What size nozzle?
What kind of prices are you charging to apply a solvent protector for furniture?
jcooper
IL
Jerry Cooper
Seems like you'd not only be putting down way too much product but also allow a lot more vapor in the air. ????
Then you are doing it wrong....
The solvent protector larry(cobbs) makes smells delightful!
Hawaii
So which sprayer can one use and leave the solvent protector in without rinsing it? The stainless TWBS pump up? I want a dedicated solvent protector sprayer...
Reactions: Jimmy L
Hawaii
Multisprayer.
Your reading comprehension ain't too good is it?
I read that but a multisprayer is cheap to have sitting for a long time.... Maybe it'll make me sell more protector.... I was kinda interested in the SS TWBS or a Pepsi sprayer....
KevinD
Binghamton,New York
Kevin Dumas
I've had my hydroforce 1 1/2 gal ss pump with handheld gunjet for (I can't remember how many years).
It never gets rinsed. All I do is add more product and every once in a while lube or put a new piston cup in the barrel.
I have a Stainless pump up so just have to find a gunjet.
Where can I pick one up other than those expensive ones that interlink charges too much for?
Also would Hardballs protector be better?
KevinD
Binghamton,New York
Kevin Dumas
Reactions: Jimmy L
