adamh
I have three vans. My back up van has a little Prochem Blazer plus in it. The way the manufacture had the vac plumbed was pretty stupid so after a few mods I have it breathing right. However, the heat is not great.
I have never used a fuel fired burner before. I would like to add one to this unit. It is my back up unit so I dont need a flame thrower and I dont see the need to spend a lot of money on it but I would like more heat. Please tell me what you have used and what you think I should do. I have a 120 volt inline heater that I use that helps with another 10 degrees or so but not enough. If you are cleaning a house making lots of vac passes and moving furniture the heat is fine but if you are cleaning an empty house you kill your heat quick.
DOMOARIGATO
DOMOARIGATO
