BATTERY POWERED MULTISPRAYER Pump model number?
I think my pump is going out.
Does anybody know the model number of the pump etc. and where I can get a replacement cheaper than going thru the manufacturer?
You might look at Harbor Freight if you're looking for cheap.....
That's where Larry C. shops.....
-JB-
JB
Das da one!
A couple years ago! Geeze D, how the heck did you remember that?
What are you like the Internet version of Rainman,
"ICS, ICS definitely, definitely saw it on ICS." :lol:
Brian L
Brian L
That is real close Derek.
I just went to the garage and measured my old battery. The dimensions are the same the only difference is mine has a F-2 connector (.250) and the one on the site has an F-1 (.187).
My old one says:
Unipower WP7.5-12
12 Volt, 7.2 Ah.
vincent
Vincent Sapp
Batteries plus has the battery for $29. The pump I am not sure about. Chad should know, he is always having problems with his.
Ask Chad-der, he always has one apart, he would know what kind of pump it is.
MicahR
Micah Richardson
I don't know how you feel about Interlink Supply Jimbo but the AP33 is a direct replacement for you.
Here's the specs
Flojet model D3131V5011 - 50psi 1.6gpm maximum flow - 12VDC, Demand switch, Viton valves, Viton diaphragm, 3/8" NPT Female ports - Highly chemical & solvent resistant pump for battery powered sprayers.
Interlinks price is 118.00 and change.
Shawn Forsythe
B,
That unit is 1 GPM, the Multisprayer original is 50 psi and 1.4 GPM.
Jimmy,
I have the right pump, call me. Flojet D3121V1311
