GeneMiller
assuming the manufacture lines everything up and tensions them correctly my main concern is heat. I use a radiator fan to keep my belts cool. Won't work well on this machine. The belts are enclosed with vents on the bottom and then vents at the top. Thanks to Ashley I have the perfect solution. I ordered a inline blower, small hood to cover the vent, and some duct. The hood will fit the vent perfect and the force air through out the top vent. I'll draw cooler air from under the truck. Perfect solution because sapphire enclosed the belts. I got the 175cfm 3"
Already shipped and on the way.
Again thanks Ashley, I would of never found this.
http://performanceunlimited.com/cobravalley_drivetrain/ductfan.html
Gene
Gene
