Belta Python 65L Dehumidifer
Microcomputer digital intelligent control. Delayed startup for protection. Automatic defrosting for protection. Up to 12 hours programmable timer. Permanent drainage option. Easy to clean air filter. Easy to carry using telescopic handle. Semi-pneumatic wheels for easy transport.
Power supply: 220-240/50hz.
Dehumidifying Capacity: 65l/day(30 degrees celsius RH80%). 35l/day(27 degrees celsius RH60%).
Max Power: 1200W.
Compressor Type: Rotary. Refrigerant: R410a.
Working temp: 5-35 degrees celsius.
Air Volume: 400m/h.
Net Weight: 44.0kg. Gross Weight: 48.0kg.
Production Dimension: 810x500x490mm.
Does anyone use these over there ??
They are a new addition to a new supplier in Australia & I just want some feed-back before committing.
Thanks,
Max Power: 1200W.
Air Volume: 400m/h.
Thanks,
