R
richd8980
or would I be better off buying locally from interlink?
Boycott Interlink
sweendogg said:http://www.superpages.com/bp/Denver-CO/ADCO-Professional-Cleaning-Supply-CO-L0136859892.htm?C=Cleaning+supply&L=Denver%2C+CO&lbp=1
I'm Sure John would do a great job, however you have a Adco which is a local cleaning supply that is home based right in Denver. You also have headquarters of Master Blend Products right there in your town. They produce some exceptionally quality products as well as host alot of local educational classes and resources.
http://www.masterblend.net
http://www.adcoprocleaning.com/home.php
You might check these fellas out. Adco is top notch and carry all of the masterblend products as well as quite a few other mainstream products as well.
grouNd meAt said:nothing against the on-line vendors here, but if you can find the same product locally, why WOULDN'T you buy local and support YOUR local economy?
(ASSuming your local supplier is reputable)
Ron Werner said:[quote="grouNd meAt":2plot8ms]nothing against the on-line vendors here, but if you can find the same product locally, why WOULDN'T you buy local and support YOUR local economy?
Ron Werner said:When Maxim Carpet Protector came out, they had no idea what I was talking about. ANd they deal with BP!
They have yet to have a 2" wand on their wall.
markup on some products is well over what is reasonable. When I started ordering stuff from the US a hydroforce was 139US or 450CDN..
John LaBarbera said:sweendogg said:http://www.superpages.com/bp/Denver-CO/ADCO-Professional-Cleaning-Supply-CO-L0136859892.htm?C=Cleaning+supply&L=Denver%2C+CO&lbp=1
Yeah I know.. well he owns Adco and coowns masterblend with Aaron Groseclose. But hey they are local and carry a ton a ton of product locally.
Not that it matters, but Adco and Masterblend has the same owner. Larry Hawk.
