Best Way to Remove Social Distancing Stickers Residue From Carpet
KSL
Massachusetts
Kent
Hello,
I have about 80 foot imprints and about a 40 foot long six inch wide line of residue from removing social distancing labels. Has anyone found a cost effective way to clean this up other than replacing the carpet.
Thanks for any suggestions.
TOPSSPOT.
Waterbased solvent, zero residue
KSL
Massachusetts
Kent
TOPSSPOT.
Hi Mike,
What dilution would you suggest for the TOPSPOT. I also came across your YouTube from the Senior Center cleaning. Would I be better off with a Fiber pad or microfiber. I have a Trinity Spyder or Cimex to use, or truckmount.
Thanks
Hi Mike,
Thanks
Fiber pad with will help break it loose but then follow up with a microfiber or glad pad to get all the wads of gummy goodness.
Start with a 50/50 mix and adjust upwards if it's giving you trouble but even at full strength it won't leave a residue it'll just smell a whole lot stronger
