Giorgio
- Joined
- Apr 14, 2011
- Messages
- 1,815
- Name
- Giorgio
Thank you.
George III said:It just occured to me that one of my regular accounts uses a lot of vegatable oil in their operation.
I'm pretty tight w/ these folks and can probably get my hands on all their used oil.
anyone have experience with Biodesiel?
Nate The Great said:Ashley Mckendree does... Hopefully he chimes in...
indyallpro said:Forget making bio-d You have by product to get rid of, glycerin, and if I remember a $10k system was only designed to do like 50 gal a week. I could be wrong but I remember it being real expensive for just a little fuel weekly.
As far as SVO (straight veggie oil) - there are few companies that sell complete kits, some are easier to do than others, some require the systems to be installed by the manufacturer of the kit.
They have kits now that after you settle & filter your raw fuel, you pump it in an in vehicle aux tank that has a HX'er that gets its heat from the vehicles coolant system.
As soon as it hits the proper temp, you flip a switch and you start pulling from the SVO tank. A mile or two before your destination, flip the switch over to your diesel tank, and you purge the SVO from the system so you are not fighting a cold start on SVO.
There are some kits that will even switch it on automatically when the SVO hits temp.
I am seriously considering it - the kit I'd need is $3K, plus $1500 install.
I'm still doing my homework, bc with 4 vans it's a major investment, mostly in the what if dept. Like what if it kills the fuel delivery system, (a pump for my vans is about $6k), or injectors that run a cool $400 a pop....., diesel particulate filters,.... the list goes on.
I may test it in one high mileage runner van, see how it does, pull the injectors, check some other parts, and decide in a year.
Burtz said:what do you do with the glycerin
they make this sound like great stuff on the green channel and muther earth magazine
AshleyMckendree said:indyallpro said:Forget making bio-d You have by product to get rid of, glycerin, and if I remember a $10k system was only designed to do like 50 gal a week. I could be wrong but I remember it being real expensive for just a little fuel weekly.
WHOOAAAA, thats 18k for 4 vans... Ive done 6 Vans, and 3 of my personal cars, and spent less than 3k on all of them.
Tell you what, Give me 10k, I'll DRIVE down and make/install your kits for you, and shine your shoes!
Walt said:Veggie oil can be turning into BioDiesel by removing the fatty acids that makes the oil too thick. Though it is natural, and even eatable, it is a good solvent that will remove paint and soften some rubber products. It can run in many diesel engines, but you will likely have problems with seals and hoses if you run it unblended with regular diesel. The processes in simple, but time consuming and messy.
indyallpro said:AshleyMckendree said:indyallpro said:Forget making bio-d You have by product to get rid of, glycerin, and if I remember a $10k system was only designed to do like 50 gal a week. I could be wrong but I remember it being real expensive for just a little fuel weekly.
From what I have read and been told, Sprinters aren't a do it yourself vehicle, many are, this one isn't.
I have dug deep into the forums for sprinters and talked with a lot of guys that have SVO systems, trying to hear just one of them tell me the companies that do make kits for Sprinters just want my install money, couldn't get that answer, they all said the same thing - don't do it yourself on these vans.
4 vans going to a company (with insurance...lol) for $18k beats the snot out of "I hope this works", when it's $40k in fuel systems in the balance.
I don't know if I'm going to do it, I keep saying if fuel hits X.xx I am, but with as much SVO as I'd need, I'm going to have to have one king kong filtering system, (I'd probably have to buy a centrifuge), some sort of a beater pickup with a 150-200 gal tank and a good pump, and a part timer whose sole responsibility is gathering, filtering, and filling vans in the evening.
I am figuring the investment is paid off on all of the above in 9-11 months, 11-13 if I buy a centrifuge (dependent on how large of one I go for), after that, because I'll be paying someone to get it from restaurant vats to tanks, I'll probably be somewhere between $.75-1.00/gal
The million dollar question is - what repair costs might there be in my future (if any), will the savings outweigh it. That's what's keeping me from pulling the trigger.
Beginning to sway me is a tax credit you can get, you have to register as an alternative fueler, form 637, activities letters AL and AM, and it qualifies under fuels from biomass. It's a big ordeal to do, IRS visits you, inserts a medium sized (and lubed) probe, but it can also be a worthwhile headache if you go through enough fuel in a year.
Though I'd love to have the fuel money back in my pocket - right now I have way too much happening, it will be a Jan/Feb project if ever.
