dgardner said:
Can't see when the soil is coming in.
hogjowl said:
Well asshole, let me tell you something. You switched to the Bissel right after I bought on of those stupid vacs you used to use ... you know ... the ones that look like the MB logo? It's nowhere NEAR as good as a Dyson! I selectively vacuumed a bank today. The carpets running from the front door to the counter LOOKED to be packed with particulate, so I Wernered it going in the typical jImMy 45/90 style, and all I came up with was a couple handfuls of powder.
Freaking waste of time!
and that couple of handfuls could have caused you to come back because of wicking.
Its also why I like the clear canister. I can tell WHEN I can move faster or if I need to slow down.
If there was that little coming in I probably would have spent about 15 min vacuuming. Not all places need to be "Werner'd".
Dyson is a good machine, but
the brush is too stiff
the machine too complicated
the filters too expensive
and I don't know if you can easily replace parts
Cleartrak is only $330, go for $400 if you buy one, buy an extra brush, the assessories, and a couple maintenance kits.
Any parts break, order them and replace them. All you need is a Phillips screwdriver for the most part.
Filters are washable and reusable many times
Only modification I've done is put weather stripping around the filter tray to make a better seal and force all air through the filter.
