B&BGaryC
- Joined
- Apr 6, 2007
- Messages
- 4,667
- Name
- B&BGaryC
Sight unseen. A 2 year old scribbled down the hall with a sharpie. What are my options? Doing this later this week.
Jeremy said:Rubbing alcohol...
Scott W said:When I am dealing with any kind of Ink - Sharpie Permanent marker or otherwise, I like to prevent it from spreading by building a wall or barrier around the stain before I start dissolving the ink. I have turned 1/4" dark blue blob of ink into 10" light blue stains when I was first starting out. This is not necessary, but helpful.
Create a barrier with StainZone, Stain Magic or similar. Then use PIG or POG or OINK or other solvent to dissolve the ink. Extract with dry passes. No need to add water to the fibers. Water just repels your solvents.
If you don't remove all the ink with a solvent - this sometimes happens especially if home-owner has tried to clean before you arrived - use an oxidizer such as StainZONE to get the last bits of colored pigment out.
Finish by flushing with hot water.
Nate The Great said:[quote="Scott W":3pxmecxb]When I am dealing with any kind of Ink - Sharpie Permanent marker or otherwise, I like to prevent it from spreading by building a wall or barrier around the stain before I start dissolving the ink. I have turned 1/4" dark blue blob of ink into 10" light blue stains when I was first starting out. This is not necessary, but helpful.
:shock: :shock: :shock: :shock: :shock: :shock: :shock:floorguy said:Nate The Great said:[quote="Scott W":2ndj7bqj]When I am dealing with any kind of Ink - Sharpie Permanent marker or otherwise, I like to prevent it from spreading by building a wall or barrier around the stain before I start dissolving the ink. I have turned 1/4" dark blue blob of ink into 10" light blue stains when I was first starting out. This is not necessary, but helpful.
Hey Scottie, why the heck does StainZone smell like ass? Seriously, this one old customer thought someone ripped a stinky one.... It was hillarious and I couldn't stop laughing but I don't like using it because of the smell only as a last resort...
