Jamesh921
Why is a bladder pump necessary for use with a fresh water tank?
What happens if you don't use a bladder pump?
Thanks
Thanks
I thought you were talking about something else.
That's it.meAt said:I'm not even sure I know what a "bladder pump" is... :shock:
Wouldn't a Flojet pump be considered a bladder pump??
or are we talking about an expansion tank that goes in-line between fresh water pump and water box the TM pump draws from???
Jamesh921 said:or are we talking about an expansion tank that goes in-line between fresh water pump and water box the TM pump draws from???
Yep, that's the part I'm talking about.
What is its significance?
Can a fresh water tank be added to a TM without a bladder pump? Why? Or why not?
Dirk said:Aren't there pumps (bypass pumps if I remember correctly), that don't require the bladder?
