Sevenmacs,
I almost mentioned the engine mounts, I sheared many of them, always caught them before they went though - but it's all the same issue, the frame on these guys just flexes all over the place.
- find an extra computer, before they don't exist anymore, you are likely going to need one at some point. If you can't find one, contact Zenith directly. When it starts to idle down on you, shut down, not start hot, or any other "seems like a random kill sensor failure" - that will be your culprit. For now, I'd put in a makeshift heat shield and muffler wrap it.
- find someone to solidify that frame, gusset and weld as many of the bolted together areas you can, re-drill and tap to higher grade stainless nuts/bolts as well anywhere you can.
- no advice on a flexing coupler, i'm going to assume it incorporates rubber components, and it gets ridiculously hot in that area - be ready to change them on the regular if you go that way, and install extra belts and zip tie them out of the way, when a belt fails you have more on the ready without needing to pull a coupler apart.
- look for any wires on that TM near hot components, many of them had wires way to close to the hx'er components. Muffler wrap is your best friend here.
- if you have the vacuum driven diverter, same deal, muffler wrap those hoses, put longer ones on and reroute them away from the metal exhaust and diverter components.
- a lot of the plumbing in these were left to lie and rub, cut up some old hose split it, wrap areas where hoses and hp lines rub on anything or lie on anything.
- keep the machine descaled or put a softener on it.
- you have a solenoid under the water box mounted on the frame, another part I'd look for and hang on to a spare of, same with all the temp kill switches in the HX system.
- I'd highly recommend changing the cast zinc coated blower inlet out with an aluminum one like
Prochem uses, with a relief built in it. That cast elbow will consistently let rust chunks freely be eaten by your blower, all it will take is one a little to large for it to chew and you'll be replacing it again.
- keep a metal coat hanger with you, when the diverter susyem fails, you can rig it half open half closed to at least get you through a day or two to fix it (diverter issues were a big problem for us). You can get the control arm from grainer, another have on the ready part. when that goes it's either your arm, vac line, or the diverter solenoid valve.
- biggest piece of advice, start putting money aside for another TM. I wouldn't count on another 2000 hours out of this guy.
