Re: Ain't it purdy?
Please spray those skid plates with Grey anti-slip. Even AL star plate is slippery when wet.. They make a very good long lasting anti-skid for AL boats.
They look good bob, Having it hinged on the top is great.
One question for you. With the legs touching the ground, you might have a problem with it getting tweaked due to the resting points won't always be level? They look like you had them built skookem enough not to have the legs go past the lowest step if you add a couple of right angle braces that rest aganst the side of the box from the top step to the bottom. That should give it all the support it needs and fold in with no obstruction so you could use them where ever you park regardless of the terrain.
