Bubble repair advice needed
Lyman
Johnstown new york
Lyman
The church I go to has gdc in the basement on plywood that has some big bubbles and ripples. I need advice on how to tackle this.
Stevea
If you go through some of the information here, I did post a series of photos showing this.
Let us know if you need more help.
SA
Lyman
Johnstown new york
Lyman
There are 2 rooms, one is 20 by 30 and the other is 30 by 50 and the problems is in the middle. I was thinking injecting glue and weights.
Stevea
Lyman,
Here is a slide show on how to repair bubbles. I hope this helps, you do not want to do this with a needle, way too much work.
It should be self explanatory Click on the photo to start the slide show
I hope this helps, if not let me know I do have video showing how to do this.
SA
Stevea
Lyman,
The adhesive is called Bubble Glue and you can look up Shagtools.com, I think that is the correct one that has the adhesive.
I also PM you.
SA
