Butler Chemical injection pump problem info
Got a shout out from someone with Butler Chem injection always running.
Shutting off the chem injection and kept working
Checked the Bleeder line to make sure fully closed...Chem kept going....
New Plunger inside Chem injection pump was needed as if the plunger is worn out, no place to go but down into the Cat water pump.....
