Butler Truckmount leaky shut off valve? Tighten the nut!
Grand Rapids, MN
Hot water valve had a drip and can cause your water gauge to engage during use from loss of pressure.
My hot - cold adjustment valve was leaking a bit too from so much use. We turn down the temps for applying our P-Lime-Zyme bacteria enzyme treatment. Use can loosen the second nut on these valves. Just tighten that down and you probably will fix your problem and get many more hours of use out of the valves.
Special shout out to Marty the Alabama pig farmer carpet cleaner @hogjowl
#SaigersSauce1
#SaigersSauceOne
#ButlerTruckmounts
#FixingYourButlerTruckmount
