Butlers W4500
Still not enough room IMO
* Instrument Panel with Dual LED Color Coordinated and Illuminated Rocker Switches . Cold Water Convenience Inlet . Hot Water Convenience Outlet . Detergent Control Valve . Dual Wand Fittings . Gauges include: Tachometer . Water Pressure . Water Temperature . Vacuum . Hour Meter . Detergent Flow Meter
* Equipment Shroud Molded and Contoured Black ABS High Impact Plastic
* Clutch Activated Cat Pump Model #435 Customized to Butler Specifications
* Butler Maximum Vacuum/ Blower System MD 4007 Competitor Plus Customized to Butler Specifications
* Diesel Heat System
* Ultra- Quiet Silencer System
* Stainless Steel High Pressure Heat Exchanger Heats Water to 220°F Plus*
* Stainless Steel High Pressure Detergent Injection System
* Braided Stainless Steel Hoses with Quick Disconnects or JIC Swivel Fittings
* Steel Drive Shaft with Concealed Inner Shaft and Bearings
* Simulator Nozzle
* Stainless Steel 10" Double Bend 3- Jet Floor Wand with Ultra Smooth Glide and Spray Shield
* 110 Gallon Stainless Steel Recovery Tank with Automatic (Fill) Shut-Off Water Level Sight Indicator, Dual Filter Bag and Tray, Dual Wand Fittings
* 150’ of Heavy Duty Vacuum Hose with Swivel Cuff
* Vacuum Hose End Holder
* 150’ of Heavy Duty Pressure Hose with Fittings and Shut-Off
* 50’ of Heavy Duty Supply (Garden) Hose with Fittings and Shut-Off
* Hose Guide and Security Door
* Hose Storage Brackets (2)
* 10' of Storage Shelving
* Furniture Tab Holder
* Furniture Block Storage Container (2)
* Carpet Rake Holder sets (2)
* Butler Portfolio Pad and Calculator
* Stainless Steel Stair Tool
* Stair Tool Bracket
* Wand Holder and Stop
* Butler System Schematic
* Water temperature can exceed 230°F
Standard and Optional Equipment prices including specifications and descriptions are available for the Butler System, cube vans, trucks and bodies upon request.
Prattville, Alabama
That truck is just what I have been waiting for.
Seriously!
Now, that doesn't mean I'm going to purchase one anytime soon, but when the time comes for my next purchase, I think that will be it.
Assuming the owner reports are good at that time.
Marty will wait till he can talk someone into lettin' him "DEMO" it...
ultimate TM
Mikey,
Here is your chance to design the ultimate Truck Mount.
Name any Blower,Pump,Engine,Truck,Body and configuration.
Performance ,Dual Wands,Pressure,Vacuum,Noise,Hose size,Reels,Wands,
Vac Tanks FW Tanks,ETC:
Put a price on it.
Thanks,Judson
captaincarpet
Kennesaw Ga.
Thomas Cermak
To really give V/AT a run for the money, they would have to step up the POWER!
220 degrees and a 4007 blower is not even in the same league as the Big trucks.
IMHO
Re: ultimate TM
judson jones said:
Mikey,
Put a price on it.
Thanks,Judson
Ok.
Take a Ford LCF with the 6 cylinder. V sized box is perfect for my area. Rear step needs to be 2" higher though. Roll top door in back.
Use a 6008 series with a dual splash, a Cat 5CP Blue Line Hose real with a divider-flange that splits the reel so 2/'3rds holds 2.5 and 1/3 2".
Use the round V waste tank with a APO that wont clog. Three 2.5 ports to filter box that restricts as little as possible (if possible)
Use the round AT fresh tank but sit it upright next to the waste tank, side by side for more floor space.
Either BL's or AT's HX system. If BL hasn't figured out how to fix the leaks then go with AT's.
Lots of racks on the ceiling for wands, rakes, tile tools etc.
Use enough silencers so I can clean at night next door to Mrs Kravits.
3 pressure/garden reels too..
How about 60 grand?
Jimbo
I'll get a MikeyMount...maybe Greenman can help Les and Judson to build it.
