boazcan
After -
After
After -
After -
White olefin berber, 250 sq ft bonus room. As you can see some areas are much thicker than others. I cleaned up some brown and green in 3 other rooms and stairs with O2 and a little extra Scotts Citrus. Spotted with prosolve.
I test cleaned some of the other spots with Prosolve, straight snake oil, magic bullet, pig out. all seemed to work pretty well. There was still a very light "shadow" of the spot with the black paint.
Curious - how would handle working all those spots? CRB the entire room with a heavy prespray and spot what is left or go after each spot with a furniture tool to keep the spreading and wicking to a minimum. Anything in the ingredients that should make me go for something else out of the spotter bag?
After - Used 8oz JJ, 4 oz Scot's Citrus, 8 oz power gel mixed with HOT water. sprayed on, let sit for 20 mins, scrubbed with CRB real good. Cleaned, repeated, cleaned, hit the few remaining with straight power gel, scrubbed, cleaned, fan - out.
$19.99 per room no up charge for spotting - need some fine print on that one...... :roll:
