Do brass floats ever need to be adjusted? Seems like mine is somehow not filling up as much as it used to.
It's like the float has to go farther down to keep it(waterbox) full. When the issue first started happening, waterbox would empty & pressure would drop. I'd have to go out to the van and push the float down(more) with the end of a hammer. Somehow it fixed itself, but it's(waterbox) lower than before.
Is this something that can be adjusted? Do floats get out of adjustment? How? Do new floats need to be set up/adjusted before the machine is built?
Actual float seems to work just fine.
Thanks fellas
Thanks fellas
