steve frasier
how well do you believe carpet cleaning will remove fleas and the eggs
I learned from having a renter with a cat that you have to spray everywhere a cat can go, on top of refrigerator, drapes, window sills. Fleas suck.
I wish!I'm in Southern California and don't come across that anymore at all. I think since advantage and such came out for the animals it has taken care of the problem at least from what I've seen.
There was a product you could use for fleas called M7 that worked really well
tell them to sprinkle boraxo all over the carpet, leave it for an hour then vacuum it up. go clean a couple weeks later if they still want it done.Just looking for general thoughts on how well cleaning removes the fleas and eggs, not going to make any flea killing claims on my part
I wish!
As someone who has bunch of indoor cats & dogs I can tell you that it does not work. Particularly if they can go outside.
Some work for a short time and then the fleas and ticks become resistant.
The only time, and not for lack of trying, that I did put an end to it was when they were solely indoor. I took multiple products, some external and some digested, multiple rinses of pets and carpeting etc. And it took a very long time.
Not touching on the issue that those products are definitely not too healthy for your pets.
To those that say it can't be done. You obviously don't have a Tractor Supply or Farmers Co-Op : )
Sure you may be able to do it for your own home. But, to apply the same for an other is against the law.
The only way to guarantee 100% elimination of all pests in a home is to bring the temperature of everything in the home including the structure to 145deg.F for 15 min.
