It creates more lift, about 60% of what the back end vacuum motor is rated at.
I have two vacs in parallel that blow their exhaust (230 CFMS) into one hose. There is a relief valve or a vent to let out higher CFMs then what the back end vac has in CFMs, the back end vac has 115 CFMs. I also have a one way check valve in the PVC pipe, this helps to blow air flow out of the vent instead of blowing on the third vac, higher CFMs then what the back end vac is rated for, may make the third vac spin faster and pop a breaker.
Most times when I put the wand and always when I put the Rotovac 360 on the carpet, the air flow slows down. So when the CFMs get low from the two parallel vacs, the vent will close and then the third vac will pull 115 CFMs, plus the third vac will add about 70 more inches of water lift for a total of about 215 to 225 inches in lift.
The set up should pull 220 inches of lift and maintain 115 CFMs under heavy loads when cleaning carpet. If I was to only use two vacs in parallel, I may not even get 90 FCMs when I use the Rotovac 360i.
When I use Rotovac 360, the sight tube shows the water moving faster under load then I use the air flow regulator set up. My wand is even a little bit more difficult to push and lift on some carpet types.
