nwhmbiz said:
OK all you high heat carpet cleaners. At what temp do you start worrying about creating those almost impossible to remove carpet snakes?
And what is your favorite temp to clean with?
I cooked .....permanently distorted/melted a cut pile olefin once at the entrance where the sol line laid the longest.
That was with steel braid GoodYear Ineptune.
That can and WILL happen w/steel braid line with extreme heat, long duty cycles on the wand trigger and the line laying in the same spot 10 -20 minutes of more, as in our case.
Fortunately for us, it was gross filthy damaged cheap olie crap the slumlord wouldn't replace.
I doubt he ever noticed it among the mass quantities of ciggy burn holes, tatters and tears on the worn out POS rag
and I wasn't about to mention it him.....
I don't know what temp we were running, as my temp gauge pegs at 280...I'm "guessing" we were hiss/spitting a good 250-260 at the "wand"
when we did use steel braid Ineptune crap,(for about a year and half) i was always careful to keep the line from laying in the same spot for long.
what Scot mentioned was pretty common too, though dried out pre-spray and "snakes" are reverable..."true" pile melt/distortion is not.
I "think" olie starts to melt/distort at 180 degrees ....and steel braids will get that hot
we don't have those issues with Parker thermoplastic
cause it doesn't get as hot to touch as steel braid.
You can still dry out the pre-spray w/Parker, but we've never permanently melt distorted with it
