Cat Pump Clutch Removal
Shane T
Shane Tiegs
Working on a Cat 3CP .Trying to remove the clutch from pump shaft but it is really stuck. Center bolt is out, penetrating oil and then incerted 2 bolts into the rotor to puch it off but it won't budge. Any suggestions? Thought about some heat to the armature?
3 point puller should break it free then it will slide easily.
